Carpet Help
I have a 2008 Cab and have removed the back seats and seat belts. I would like to repair/replace the back carpet which has holes for the seat beat fitments. I did this with my past 2006 Coupe which was easy because I could get the GT2/3 rear carpet from the dealer which comes with no rear seats. Does anyone know if the Coupe rear carpet is the same as the Cab? Any suggestions?
I contacted Porsche North America for help. Same question, is the Coupe carpet the same as the Cab? Their answer was, we don't know and there are no carpets at the assembly plant in Germany to look at. I didn't realize Porsche was building 997's without carpets now.... Anyway, they basically said, don't know, can't help, don't want to help. The same response I have gotten a number of times when I contacted them.
Would appriciate any help. Thanks.
What 'specifically' are you seeking information about on the carpet? If they both have holes? Or same 'type' of carpet?
Per the ordering guide and our samples- there is no difference in the carpet- coupe to cab.
In response to the question from Bills911997, try checking the parts catalog. The catalog can be found at https://techinfo.porsche.com/techinfo/index.jsp This will tell you if there is any difference between Coupe and Cab.
