Wierd Clutch Issue
Old Jul 16, 2008 | 03:29 AM
SmellyPenguin's Avatar
SmellyPenguin
Default Wierd Clutch Issue
I have a 06 997S with ~40k miles, second owner at 22k miles, and so far apart from the notchiness going from 2nd to 3rd, the gearbox has been awesome.
I had the car parked today at a parking lot, when I started the car, I heard a weird screeching noise from the engine and the car didn't start. I took the key out of the ignition, put it back in and started it again, the car started with no problems.
As I'm backing out I notice the clutch pedal had gotten very heavy and the clutch's "bite" point had changed; I had to disengage more of the clutch to get the car going. Keep in mind everything was fine prior to parking the car.
I drove around a little bit, the "bite" point is a bit better, but still worse than it was before and the clutch still has a very heavy feel.
Did my clutch magically die? Or did the screeching from the engine kill it?
Old Jul 16, 2008 | 07:45 AM
Deanski's Avatar
Deanski
Have the slave cylinder checked, it may be leaking.
Deanski
