Routing BTA1500 Bluetooth mic wire from truck to cabin
I tried searching but couldn't see any thread on this. Can someone point me to the best diy way to route the mic wire (BTA1500) from the Dension 500 in my truck to the cabin? I couldn't see any visible opening in the trunk. Perhaps I have to start taking some parts apart. Any suggestions?
Thanks.
Kevin
Thanks.
Kevin
I want to do this too. I've searched, and have found the answer to this particular question (i.e., the grommet behind the battery). However, I can't find any pics or DIYs about how to specifically get the mic from that grommet to the inside of the steering wheel column... if anyone wants to chime in, go for it!
Poseur
How far is your cabin from your "truck?"
Assume you meant TRUNK and are trying to get into the cockpit. Take some panels off around the battery and you should easily see a convenient hole.
