How to lower a base 997 ? Need help from you experts
My 08 997 base Carrera has a 19" wheels, and it has a significant wheel gap (to me since I'm always concious about it) compared to the already low Carrera S. By the way, why are the S low? Different springs than the base?
I lowered my Mercedes with a H & R Sport springs, but what brand do you guys recommend for the 997 and with which product? Oh, the spacers are the ones that make the wheels stick out from the car, right?
I wonder why all sports cars are not manufactured with the low springs when almost all the people get aftermaket springs.
Cheers
Cheers
The S has the PASM suspension standard which lower the car 10mm.
The base car doesn't have PASM, it's available as an option.
You can lower your car with short springs or better with coilovers (a lot of choices for the base without PASM). The advantage of coilovers is the ride height is adjustable so you can set them up exactly to your liking. Also most of them are adjustable for rebound and dampening. The downside, they are more expensive than springs.
Order an 09 with this.......
P17 PASM Sports Suspension Package
Electronically variable active damping system with two manually selectable
modes and limited slip rear differential lock. Ride height lowered by 20 mm.
Base $2940
S $950
Gotta hand it to porsche, only took em 5 model years........
Base $2940
S $950
If I was going to keep my car I would want to lower it and I would use H&R springs. All the Porsche GT3 springs are H&R...the H&R stamp is even still on the springs. Porsche has been using H&R in there cars for years.
The H & R's were too low for my neighborhood with the Aerosport (GT3) front bumper cover. I went back to stock but hated the look so I bought a set of PSS9Damptronics which allow me to adjust the ride height and counterbalance. There is a significant price difference between the 2. H & R springs are about $500., and about $2,500. for the PSS9/10's w/ Damptronic, a few hundred less without.
