Dension Customers, ready for Bluetooth?
#31
Basic Sponsor
So Eric what are my options IF any for bluetooth in the vehicle then?
Also I was part of the group buy initial for the ipod Gateway500; and I have noticed since installing the latest software/firmware flash I no longer get it to charge my ipod touch thru the cable, why so?
Parrot may be the only 'best' option if you do not have the phone buttons.
Is the iPod updated? Connect to iTunes and update it, then do a hard reset on it (hold at 12 and center until it blanks out), then be sure it is in sleep mode.
If it charged before, there should be no reason why it would not charge now. Using 2.11 or 2.10?
If you need to revert, email me and I'll send you 2.10. Did you always use the iPod Touch, or is that new? If that is a new unit, then you need the updated cable on the Order page which resolved some of these issues a few months ago.
eric@bumperplugs.com anytime for questions/updates/issues.
Thanks.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
#32
Eric, question. How long are the wires? The Gateway is in the trunk of my Cayenne, how long is the BT1500 wire, and how long is the MIC wire to end up installing this in the mic location on the dome light area?
I think the tooki may end up going in the 997...
#35
Eric,
It works with the iphone apparently. But can you still use the ipod functions of the iphone without having to switch to airplane mode (and without having the static feed-back when not in airplane mode?)
#36
I'm having Bluetooth reception problems because my BTA1500 is mounted in the front trunk.
#37
Basic Sponsor
Jeff - most success has been mic near the dome lamp, driver side.
#39
Thanks.
Thanks.
Ipod is updated and was working fine with my 20gig Ipod and then the Touch too until like I said I upgraded the Gateway and noticed the charging problem.
#41
I have neither the GW 500 or the BTA and would certainly like both.
One of the posts mentions the risk to the overall warranty of the car posed by the installation of the GW500. How big a risk is this? Is it a concern to others here that any future problem associated with the screen/Bose/PCM/CD changer/etc. may then be attributed to having added this regardless of the true nature of the problem?
Kevin
Kevin
