Conditioning Leather
Not the best thing for Porsche leather. Lexol was first used on tack/saddle leathers, then someone used it in their car. That car has uncoated leather, so Lexol worked well. That's unless you HAVE natural leather which IS avalible from Porsche.
Todays leather is coated. Treat it as such. Use water based leather conditioners.
There are far better conditioners, Zaino, Sonus, 1Z, Leathermaster, Griots, etc.
Some contain some leather fragrance, some do not. This is the point where you have to test different ones and find the one you like.
I like a few. Sonus, Zaino, 1Z.
Cleaning: Save your money. Use Woolite and distilled water start at 15:1 then if it does not clean, drop down to 6:1. Most leather cleaners are just nothing more than soap, fragrance, coloring. Use white 100% USA cotton towels to clean with to gauge your level of dirt. Once clean, I mist a very light amount of clear water to rinse, then dry really well. After that, I let the car sit with windows open to assist drying the moisture out. Then apply your conditioner but lightly, do not think more is good, it's not.
I wish more companies would offer leather conditioners in small sample bottles so those that want to try a new product , but do not like one of them, you're not stuck with a full bottle and out the cash as well. It's so subjective that only trying several types until you find the one that really makes you happy in both feel, wear, smell.
Deanski
Deanski
If parked outside to sun often, try whatever you can to keep the sun off the dash.
Some have treated the dash after a leather conditioner with 303 to add more UV protection, but I would not. I just use a sun windshield shade to cover up from sun.
It's best to keep it clean and treated due to having not only a windshield to deal with, but air vents that can also dry the leather near them.
Deanski
Deanski,
Is the Sonus that much better than Griots? I'm mostly concerned with smell and I also don't want it leaving the seats slick like Zaino does. If you feel the Sonus is better maybe I'll purchase some.
Sonus is especially made for Porsche leather. It's the best product out there for it that I have come across.
I have to agree with Ben as well.
Sonus was developed by David B from Autopia and is a Porsche owner as well. He used Porsche leather skins, new in the bags to match a way to release the natural tanning oils from the leather so not to mask it with heavy leather fragrance.
It also has a very unique way of feel after it's applied. It makes the leather feel somewhat more firm and have more of a gripping feel to it, the exact same way it was when you took delivery or were sitting in a new showroom model.
Out of the bottle, it has a very odd smell. However, once applied to your leather, close the doors and wait about 1/2 hour. Then, open the doors and be greeted to the smell of new leather the way it was when you did take delivery, minus the plastic/vinyl overtones.
I really like the way it looks as well, not glossy or oily at all, the opposite. Very flat looking as it should be.
Now, if someone has Porsche natural leather which is untreated/coated, you have to use a different conditioner that contains heavy oils and lanoline etc to keep them from cracking and drying out too quickly. Some people use the Leather Masters line or Leatherique oil and Pristeen Clean. With Leatherique, you apply the oil first, THEN the cleaner. It's a messy application, but works very well for untreated/coated leather.
I think you'll be very happy with the Sonus. Just make sure the leather is clean and dry prior to application and only apply enough to wipe on, not soak the leather with it.
Regards,
Deanski
Regards,
Deanski
You can check by option codes, but natural leather is not dyed from what I understand.
If it's "Full Leather" and not Nautral leather, then you have coated.
Another easy test: Use one drop of water on he leather. If it sits, it's coated, if it gets absorbed, it's natural.
Deanski
Deanski
