Winter storage
I was wondering, those of you who store their P-cars in the winter:
Do you start them up from time to time not? The manual doesnt say anything about it in the storage section. I have not myself. But should i be worried about drying up the seals/gaskets and such. Or is it better to just wait until im ready to take it out?
No don't start it from time to time. You'll never get the acids within the oil/gas mixture burned up only by starting it and running it at idle or a few revs.
After winter this is my steps. What I did is pull the fuel pump relay, turn the car over until I get oil pressure, reseat the relay, then start it, let it come to operating temp, then drive it.
Prior to storage, I change oil.
Deanski
Deanski
Unless your engine has been properly prepared for DEEP storage, it is always best to run it periodicaly to and beyond full temperature than it is to just let it sit. There is always moisture in an engine and left to sit oxidation occurs as well as acids will build up. Running the engine cleans this oxidation as well as removes condensation from all areas of the engine and recoats most areas with oil and coolant. It keeps both the engine and cooling system clean including valves and plugs. You want to get your oil up to about 200F and let the engine run for 10 - 15 longer. If you have a manual tranny, put the car in neutral and engage the clutch. This will warmup the tranny fluid and coat the gears. Tip should be put iin gear a few times.
If you cannot periodically run the engine and properly prepare it for deep sleep, at least let the engine injest a pint or more of transmission fluid through the intake. This will coat most areas of the engine and exhaust with a protective coat, helping to minimize oxidation.
looks like the OP is from jersey by his license plate. It was 65 degrees out the other day up here in NY...on days like that how can you leave your car in the garage, even if its February?
3 cars, no issues.
Don't worry about storing it. Plump up the tires, hook up the battery, top off the gas and cover it. I've had 2 996's and 1 997, stored them all every winter in an unheated garage,(we're really talking 5 mos. here, N,D,J,F,M) and forget it. No problems in 9 years.
I believe I did read in the manual about starting the car when you store the car for winter. I believe if you did not have the car on the battery trickler, they wanted you to start the car every 5 to 7 days. If you do use the battery maintainer you can go longer without starting the car.
Stickshift964, I live in Jersey and indeed it was a balmy 65 the other day! I had my C2_S out and enjoying it. Believe me this winter has not been bad at all. Knock on wood!
I live in NY and have driven it EVERY day this winter. Its a well built car and deserves to be driven. My personal take is that I bought the car to drive and enjoy and even on cold days I do not enjoy it as much when it is sat in the garage being a queen!
What is the worst that can happen?............it gets a bit cold and dirty? A wash works wonders!!!!.
ENJOY it!
ENJOY it!
Poseur
There is a lengthy article on winter storage on the PCA website. Things to consider are overfilling your tires to minimize flat spotting, and putting a fuel stabilizer in when you fill it up. (Keep the fuel tank full). Change the oil just before the slumber. Tape up the exhaust pipe,--a lot of moisture can enter an engine that way. Place rodent traps and bait at each wheel (depending upon your situation).
This was my checklist when I was putting my 993 in to storage each winter:
Run A Tank Full Of Chevron Fuel Injector Cleaner (With Techron) Before Oil Change
Change Oil & Filter (every year)
Change Brake Fluid (every other year)
Change Transmission Fluid (every other year)
Remove Battery And Wash Area With Baking Soda
Lubricate Battery Terminals
Clean Interior Carpet And Leather, Including Trunk Area
Condition Rubber Seals, Trim, Etc. (Aerospace 303)
Clean Convertible Top With RaggTopp
Wash Car And Engine Bay
Clean Wheels
Seal Convertible Top With RaggTopp
Wax Car (ZFX *2, Z6, Z5, Z6, Z2, Z8)
Fill Gas Tank And Add Stabil (Run Engine To Circulate Stabil Through System)
Over-Inflate Tires To 50 PSI
Cover Openings In Engine And Exhaust With Aluminum Foil
Moth ***** In Or Under The Engine Compartment (Put In Sock)
Open Doors (close to one ‘click’)
Plug In Battery Charger
Release Parking Brake (Ensure In Gear)
Cover Car
Clean Wheels
Cover Car
Looks like there are different views out there with regards to starting vs not starting up while in storage. I m tempted to start it to lube the internal parts but i know ideling is also not good, I agree that it will not burn off the acids and moisture as some have noted moisture in the oil fill cap after short drives.
So, please explain why, as far as the engine is concerned, idling is not good. I would love to hear about it.
Maybe an oil temperature of 200F while idling is cooler than 200F while driving.
I'm not sure exactly the reason why idling is discouraged. One is envionmental. Also you would be putting wear on the motor without actually driving it.
As far as warming it up every often; i think it needs to be driven to get the moisture and acids out. For one thing Idiling doesnt get the oil pressure up and even if it did you'd have to idle for a while. I think just the act of getiing the revs up for a constant amount of time ( like while driving) helps more than idiling. I even wonder if idiling is worse than not starting it all.
Thats what think anyway
I dont have a scientific answer; i was hoping to get one from one of you.
