Solar Battery Maintainer
Has anyone used a solar battery maintainer?
My "other" garage does not have power, so this is my only option unless I pull the battery out.
Thanks guys!
Regards,
Deanski
Thanks guys!
Regards,
Deanski
As soon as I saw Deanski's post, I thought; "Who the hell would leave one out that long?"
...But: why not run a wire out a window and place the solar collector on the roof? I know guys who use them for airplanes that seem to get flown less often than P's are driven in Winter.
That's what I'm doing, leaving it outside on the roof. I'm sure the association will have a fit, but what the hell. I need to charge the darn thing during winter.
Deanski
Deanski
a battery tender draws very little current. you might try buying one of those portable battery pack jump starters which also have outlets to power accessories, charge it fully in your house, bring it to the garage and plug the tender into it, and see how long it lasts. maybe you can get a week out of it, then recharge it in your house.
The best thing to do is go on a boat forum like hunterowners.com. There is a wealth of information on solar there or any other sail boat sites. If all you want is to trickle your battery and maintain its charge ...then its pretty straight forward and companies like Westmarines can help you. They have complete units ready to use that are small. They also come with regulators and diodes that prevents the battery from discharging when its night time or no sunshine.
Thanks all,
Looking at several panels just for battery maintaining. Here's one that's weatherproof as well.
http://www.siliconsolar.com/12V-Sola...W-p-16678.html
It also has a 20' extension which is nice. I'll put it up on ridgeline or a bit over, and run the cable through the ridgeline cap.
I'll also have to search the forum on removing the battery just in case the association has a problem with the damn thing.![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
Regards,
Deanski
Regards,
Deanski
