Driving in winter
Old Mar 16, 2008 | 11:14 AM
p-cardriver's Avatar
p-cardriver
Originally Posted by yell03
I wonder if I can get Turbo rims in 18", I love how they look on the car.
Howard
Here's where I got my wheels... mine are copies, not original, but I think they sell both. I went with Carrera III because I thought they'd be the easiest to clean - and I don't enjoy that task in warm weather so I knew I wouldn't in the cold!
http://www.wheelenhancement.com/index.php?t=Wheels
Old Mar 16, 2008 | 12:53 PM
ajag's Avatar
ajag
Obviously narrower width is better, but does dropping diameter from 18->19 for the winter set make a big difference aside from saving a bunch on the tires? I was planning on running my 19s this summer and putting winter tires on the stock rims and then going with 20s next spring for my summer set.
Old Mar 16, 2008 | 01:16 PM
Chris from Cali's Avatar
Chris from Cali
Generally, the shorter the sidewall, the pricier the tire...
Old Mar 16, 2008 | 01:57 PM
ajag's Avatar
ajag
I know, just wondering if the winter performance suffers as well with a short sidewall, all other things being equal.
Old Mar 16, 2008 | 02:00 PM
yell03's Avatar
yell03
Thanks, I will check it out.
Most guys go to the 18" with not as low profile because it is more forgiving if you hit a pothole.
My 1st choice is to stick with my stock 19" rims, but I will cry if I destroy a pricey 19" Turbo rim.
Howard
Old Mar 16, 2008 | 02:56 PM
drj9000's Avatar
drj9000
Snow tires are essential, all season tires are actually 3 season tires. Once it gets below 5 degrees Celsius your summers or all seasons will get hard and lose traction even on dry pavement.
Old Mar 17, 2008 | 06:06 PM
Chris from Cali
Performance is definitely limited with winter tires in dry weather. I found out (almost the hard way) one winter during a dry, 55* day. If you can put 18" tires on, that's the best bet.
This thread had me do some research on Tire Rack - I found a package for the 997 C4S with 18" wheels (turbo twists lookalikes) and 235 fronts/265 rears.
