Does anyone have PSE install instructions?
Yes- you can get them at renntech.org. They are listed in the TSB section, which you need to register for to access.
If you are installing with electronic kit, the process is time consuming and quite laborious.
If you are installing without electronics, budget about an hour, taking your time. 997 mufflers are super easy to remove and replace.
