Cleaning off cone marks
Had the pleasure of doing a PCA autocross with my C4S. I used blue painter tape over the front leading edges, which are covered with a 3M clear bra. I failed to cover the OEM clear guard on the back fender flair and picked up a nice cone "smudge". I tried the orange and the green cleaners; both with no joy. Any suggestions? Thanks
WD40. yes, it does work as a cleaning solvent too.
I've used Plexus, WD40 and various waxes and polishes. Simple Green has worked the best on my rear fender guard and my clear bra. It was head and shoulders above other products in getting off tire marks. I haven't tried Windex. I scrub the Simple Green in with a foam dishwashing pad that's covered with a plastic mesh.
Thanks for the replies. Seems like more than one possibility. Saturday morning I'll test them out. Next autocross I'll use blue tape over this section also.
my clear bra is now marked up from pieces of rubber on the track hitting it and the usual day to day road debris hitting it. I have tried to remove these marks and the scratches my wife put in the bra by trying to scratch some bug marks off with her dagger finger nails. I finally got out my buffer with some Novus and Mequires plastic polish...still can not get all the marks off.
I use mineral spirits. Most drivers use the blue tape but the white masking tape works just as good at 1/4 the cost. Only difference is that the blue is for long term use. I remove my tape at the end of the day. Rinse the area with water first to remove any grit. Water also removes any marks that are water soluble. You can scrub like crazy with WD40 or thinner and they will have no effect of water soluble marks.
Lately I have started using a 3M protective film. 12" by 150 foot roll, white. Sticks OK to clean surfaces and I tape the leading edges to keep the wind from lifting it. Lots faster then using the 2" strips. I think the roll was $25.00.
Try using some tar remover and follow up with a clay bar.
PREMIER PROTECTIVE FILMS
ClearGuard PPF Specialists, Spectra PhotoSync IRD & CeraLuxe IRD, Authorized Modesta and Nanolex Dealer
www.facebook.com/premierprotectivefilms
B: 510-623-1308
sales@premiermobilegroup.com
See Our Projects! http://www.facebook.com/premierprotectivefilms
CLEAR BRA CLEANER -TRACK MARKS ON CLEAR BRA - PF1 TTR!
http://www.premiermobilegroup.com/pf1_products.shtml
B: 510-623-1308
