Homelink help
Homelink help
Hi Guys,
I am having problems setting up my homelink to my electric garage door. I follow the instructions and aim the door remote at the front of the car having already pressed the homelink buttons for the appropriate time. The car then flashes the fog lights to alert me that it has captured the remote frequency. HOWEVER then when I try to operate the door it does nothing!!!!
Am I missing something?
consider what you've done below as step 1. once you've done that you probably have to hit the "learn" button on your garage door opener and within about 20 to 30 seconds, you have ti hit the homelink key in the pcar twice, maybe three times to get ti tlock in...atleast thats the case with the most modern garage door openers that have "rolling" codes.
Hi Guys,
Try this - I've used their site with success in the past. Good luck.
http://www.eurohomelink.com/_uk/programming.html
Unless you have a very old garage door opener, it probably has a dynamic code. In such a case you need to use the learn button on your garage door motor unit. The process is detailed in the owner's manual (if I remember correctly, it is a page or two beyond the basic programming instructions). In my experience, it sometimes takes a couple tries to get it right.
I just got my homelink working after reading this thread and getting my wife to sit in my 2007 C2S, Slate, and press the homelink button while I on a ladder pushed the learn button on the opener motor. Thanks all. I want to post a pic of my wonderful new car as soon as the admin accepts my Paypal.
