997s Exhaust on carrera
I think the outlet is also a different diameter. I know the headers are different. I think as long as you get the tips to go with it you will be fine. However, I don't think there will be any real sound improvement vs. your stock set up. The 997s exhaust is pretty tame...
So, you have a C2 and you were offerd a C2S exhuast? If that's the case it will fit but the diameter of the outlet (as J1SD says) is larger. In other words,you'll need the S tips. Not sure what the benefit of making that kind of switch would bring. Why bother??
