Took the front plate off today
Just moved from NJ to PA. Knowing that PA doesnt require a front plate, I took the front license plate off today. The plate was screwed on to a black plastic bracket which was attached to the front bumper. I was expecting 2 holes for the bracket. I was shocked to see 4 holes on the bumper! 2 were from the bracket. the other 2 were from the 2 top screws used to hold the plate to the bracket. Apparently the screws that hole the plate on to bracket ALSO go thru the bumper. Cant believe the dealer put 4 holes in my bumper for that !@#$ plate!!! What the hell???
Not only was i dissapponted but now should i get 4 bumper plugs....which may look stupid or just put the bracket and plate back on and the hell with it. Any input would be a great help.
My 997S had the same misfortune.
I used (4) plugs from Eric @ bumperplugs.com.
My car is black so I think the plugs tend to blend in better.
I'm just waiting for my bumper to get more rock chips before I look for a undrilled replacement.
Thanks for the input.
I have one set of bumper-plugs already. But they are bigger than the original drill holes. If i make the drill hole bigger so the plugs fit, i wount be able to go back to the bracket incase i move in the future. Might have to use the tow hook or run w/o a front plate and risk a ticket. I didnt think it would get this confusing for the stupid plate.
i had the same misfortune, exactly. i chose the "bumper plug" route which made it both tolerable and laughable. if i would have kept the car (i sold it) the front bumper would most likely have been filled at some point.
regards
regards
I ordered a set of plugs and when they arrived I took off my plate to discover the same 4 holes. Rather than drilling them larger to put in the plugs, I used the rounded handle of a screwdriver to gently push the bumper material into the holes until almost flush then filled with repeated layers of touch up paint. I now have 4 small bumps rather than 4 large bumper plugs and it's livable..
If you have to drill, a 1/4" grommet will fit the drilled hole later on if a plate mount is needed. Simple fix. Just get on the order page and go!
You can also use a Dremmel tool to shave the plug stem down a bit to fit smaller holes.
Thanks.
Thanks.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
I had the same issue and Eric was great about sending out two more plugs quickly. It doesn't look great but does look better than the plate. I was nervous about expanding the size of the holes too, but making a bracket fit if I had to go back to a front plate would not be too difficult. I justify dealing with the plugs for now by telling myself that once I collect enough rock chips to really bother me I will replace the front bumper with an aero one.
