DIY Oil Change
I just got back from running around picking up the parts and tools and the tally is as follows:
Mobile 1 0 40W $5.99 per quart
Oil filter and crush ring $18.21 (from dealer)
Oil pan $4.99
Funnel w/ hose $4.99
Torque wrench $24.99
8 mm hex $2.99
Oil filter wrench (from dealer) $41.89 - this is going back!
Oil filter wrench (from Kragen) $5.99
I couldn't believe that the dealer (stealer) was robbing me in broad daylight of $41.89 for their OEM oil filter wrench. Even the service guy felt a little embarrassed about the pricing... Finding the $5.99 job at Kragen made me feel much better. I'm ditching going to the dealer the next time for the oil filter and gaskets too - found them online at 4 for $35 including crush rings.
So as far as the consumables go, it should cost only about $63 to do an oil change. A far cry from the ridiculous $300 that "service" wants. Why someone isn't running around undercutting the stealers business is a mystery... one can make a good living in my neighborhood for onsite oil changes. Anyway, I'm off to change the oil
John
- are the 997 and 987 oil filters the same?
-what the the torque specs for fliter housing and oil plug?
-where online are you getting the oil filter/gasket/crush washers for 4 for $35
Thanks.
Thanks.
See elh's response
Found the filters on Ebay
I'll buy one at that price if you got more!
Made by Powerbuilt, Micrometer Torque Wrench, model 644998, 3/8" rated for 20 to 80 ft-lbs. I checked other similar ones at HD and Pep Boys, but cost more $s.
Keep in mind that if you're going to use it for the wheel bolts, then you'll need one that dials up to 96 ft-lbs.
John
John
Right, this was just for the oil drain plug and oil filter housing.
Not sure if the Kragen wrench comes with a certificate of calibration, but the Craftsman does... +/- 2 lb ft on the big one, +/- 1 lb ft on the small one. That's good peace of mind for me...
Just MHO.
-d
[Does anyone know if it is a dealer prep item to "turn on" the mileage/date counter for the oil? I assume YES. Does anyone know if the factory replaces the oil after Dyno/testing? I assume NO]
My point being when you get the car, the oil (already used during dyno in Germany?) could have been in the car for many months already. Seems like really cheap insurance. I did my DIY at exactly 1999 miles, which coincided with full break-in. And yes I never broke 4200 rpm prior.
I am going to change my oil for piece of mind (presently 1850, changing at 2000). I know there is some fine metal swimming around in there.
But the comment about "wasting money"?? Porsche is about spending! There is nothing economical about Porsche.
FWIW, I wouldn’t trust a $25.00 torque wrench. I use three calibrated Snap-on torque wrenches of varying torque values; a quality tool is a life long investment.
