Tachometer needle wiggles on idle
Originally Posted by 99firehawk
dealers canot put a fault on hold, misfires can occer if a car is started with a low battery
low or old gas, or to much water into the air cleaer at the car wash.
I wouldnt worry about it
the car is smarter then you think if theres something wrong it will tell ya
6 levels of over revving? What a pile of bull****. The limiter prevents over revving. There is only one level of over revving. Forced. And each ascending rev is worse than the previous one.
Hi - I know this is years late, but may help someone.
I had misfires in cyls 4, 5 & 6, always on first start up, before the engine warmed up, seemed worse in winter/cold/damp etc... Tried the plugs/coils and eventually after some reading around, I saw a piece on the high lift solenoid and finally got my local indy to change it, (they did both banks in case) - bingo! No more mis fires
The following 2 users liked this post by RogUK69:
8x57IRS (04-10-2024),
Robocop305 (04-10-2024)
