blown engine and I have no clue why
#31
When I went through engine replacement on my 996 I was told Porsche does not recognize "remanufactured engines". They have new engines and replacement engines - allegedly.
#32
All warrenty replacement engines are reman..................that means the block and cradle and head castings are reused, every thing else would be new from pistons and bearings to the harness and accesorys.
#33
#34
My replacement / remanufactured engine (now at 9000 miles) is much better than my original - both performance and mpg wise. Then again, I guess my original was never up to spec - it started using oil at 5000 miles due to a bad ring. When I eventaully got them to take the black tail pipe and using a litre of oil every 1000 miles (after using none) they found a bad ring in six which has scored the bore. All happened 4 weeks before the warrnanty expired. Phew!
#35
Newbies Hospitality Director
IIRC, the remanufactured engines come from the original production line but did not pass Porsche specs when they tested the engine. Those engines are then torn down and rebuilt with all new parts except the engine core. They get a little more "individual attantion" which is why many have said that the remanufactured engine runs better than the original engine.
