THINKING OF SWITCHING TO 18"s ON 997S
#31
Originally Posted by Bob in NY
Remember it's a Porsche not an SL500. I would buy the S and enjoy the car but no matter which model or configuration you won't get a cushy ride.
In any event, the last 996 I drove with 18's had a poorer ride than the 997 I drove with 19's and PASM. I was pretty impressed with the ride of the C2 with 19's and PASM and was just wondering how much quieter and less firm the ride is with 18's.
#32
Tire pressure will make a bigger difference than the diameter of the wheel. Instead of changing from 19s to 18s drop 3 psi in each of your tires from the factory recommendations. Then come back and write about the ride.
#33
#34
Originally Posted by mdrums
+1, I run 33f-39r for the street and the ride on my PS2's 19" is just fine...it's a sports car and is not going to ride plush with 18's or 19's.
#35
That is 33f/39r cold tire pressure. You will find this info in the owners manual.
Just so you know on the track I run 38-40 hot all around. Drove home and adjust the pressure cold this morning and cold they were 30 cold all around. I run the higher pressure like the manual says for normal street driving to help in tire wear and to help protect the rim from any pot holes/uneven pavement. I never run the extreme high load pressure in the manual as the tires are really slick then.
#36
Originally Posted by kayjh
I'm not really after a cushy ride, but the roads where I live are not great, so ride quality is a consideration. I keep reading that the power difference between the S and non S is more apparent on paper than on the road. People on the forum that have an S disagree and people that don't seem to agree with this view.
