THINKING OF SWITCHING TO 18"s ON 997S
Originally Posted by george_k
Yes. I do have a coupe and the ride on NYC area roads is bad. I just got the 2006 CS2 used and I want to get the 19" sport design wheels off before one of them gets crunched, maybe sell them or hold them in case I upgrade cars later on then I will put the original wheels back on.
Originally Posted by David A
996 Turbo wheels should be the right offset.
Besides offset, will 996 turbo wheels take the 295/35/18 and 235/40/18 rear and front tires needed to match the stock 295/30/19 and 235/35/19 for a 997S? Are 996 turbo rim widths the same as the 19" sport design wheels on my 997S?
made the 18 switch
I am not sure about the 996 wheels, but I made the switch to 18"s
and I am glad I did, the ride improvementng is huge and the handling is great
Still trying to get the tire pressures set up correctly as the TPMS is driving me crazy. It reads 3psi low all around and I am getting warnings at my preffered
pressure - 35/40
George
pressure - 35/40
George
I am wondering...besides the PASM ( basically switchable and continusly adjustable shocks) does Porsche use different springs or other suspension components for the 911 or 911S or for cars with 18 inch vs. 19inch wheels from the factory? The reason I ask is the differnt weight for the different wheel & tire combinations might affect handling for each suspension set up with a wheel & tire switch?
pressure - 35/40
George
pressure - 35/40
George
send me a PM if you still have the Sport Design and thinking of selling them
thanks
make sure you're not driving in the "sport setting" with the shocks in the firm mode. I found that the S has a more compliant ride than the standard coupe both with 19" wheels. If you drive in NYC, 18" wheels won't give you any improvement. Most of the roads are aweful with holes and uneven pavement.
Anyone know??
Originally Posted by kayjh
Is this because of the PASM? In other words, is the suspension on the C2 stiffer than the S (in non sport mode), because it can't be stiffened whereas the PASM on the S gives you the best of both worlds; a softer ride for everyday driving and an extra stiff suspension for aggressive driving?
exactly
