shift knob
Call me a sentimentalist. Saddened by selling my 996 C2 for a 997 C4S (life's tough, huh?). Would my 996 shift **** fit the 997? I'm presuming these are all fitted with standard connectors, but I don't know if I don't ask.
I'd get an OEM **** for my current car and bring my current **** with me (ca/al). The hell with how it looks. Would do it to keep one little piece of the car with me....
Newbies Hospitality Director
Gary - Some shift ***** have a set screw on them, but most OEM ***** do not. The set screw will be up high on the shaft after you have lifted the leather boot up. If you don't see a set screw, then the shift **** just pulls off.
Be careful when you pull the shifter **** off of the shifter. It will take a lot of force, and it will come loose suddenly. You could really hurt yourself (literally) if this happens. To avoid this big "hurt" I did this:
o - Pull the leather boot up and over the shift ****.
o - Take two screwdrivers and place one in front of the shifter shaft and one behind it so they are parallel with the dash. The screwdrivers face in opposite directions so you can hold the handle of one screwdriver and the shaft of the other screwdriver in each hand.
o - Sitting in the driver's seat, place your left forearm on your right knee. With your palm facing up, grab the left side of the two screwdrivers (already on each side of the shifter shaft) with your left hand.
o - Then grab the the right side of the screwdrivers with your right hand (also facing palm up). You can now use your left knee as a fulcrum and pry the **** off. It may go flying straight up, but you won't knock your teeth out.
Hope this helps.
Hope this helps.
Thanks TIm. I may just take it to a pro anyway. I'm concerned I'll mess up the boot, let alone my teeth....
Isn'tthe boot attached to the **** somehow, though (glue)?
BTW - when I replaced the stock shifter with the B&M SSK, the hardest part of the whole project was getting the shift **** off the OEM shifter. Once I came up with the screw driver trick, it took about 15 seconds to get it off.
The 996 shift **** has a set screw .The 997 has a collar which needs to be twisted ~ 90 deg. clockwise before pulling the **** off.
The **** is not glued on, but you do need the strength of a Gorilla to pull it off. Lol
If you go to the B&M web site, they have complete instructions on how to do it .
www.bmracing.com/media/products/pdf/67.pdf
Have fun.
Have fun.
