Burning Smell
Old May 6, 2007 | 05:38 PM
jw1977's Avatar
jw1977
Default Burning Smell
I've got an o7 C2S with about 3300 miles, in the last couple of hundred miles i've noticed a burning smell once I get out of the car. I'm not sure if it's burning oil or what. Has anyone else experienced this?
Old May 6, 2007 | 06:01 PM
Friday's Avatar
Friday
All three of mine have smelled-Including my 07.
Old May 6, 2007 | 06:08 PM
larrytrk's Avatar
larrytrk
Yup my 06 S also, took it in they said brake smell, smelled like clutch to me?? They said no. They were willing to check clutch on my nickel, I declined for now, I have 12K now!
Old May 6, 2007 | 06:15 PM
Frank 993 C4S's Avatar
Frank 993 C4S
Itmight be either >Sulfur< or >Cosmoline< .
To deal with the first possibility, change the type of gas (petrol) to another brand. The cosmoline smell should go away over time.
Old May 6, 2007 | 06:35 PM
MMD's Avatar
MMD
Get used to it. There's very hot exhaust system very compact next to engine with hoses, oil, insulation, cosmoline etc.; rear-engined car (compacted exhaust system) will stink up the whole garage. I had an exhaust fan installed in the garage for this car.
Old May 6, 2007 | 09:46 PM
malammik's Avatar
malammik
Hmmmm. I find it odd when there is no smell. Burn that biatch. Does it happen after every trip? Do you drive aggressively especially last couple of minutes before you get home?
Old May 7, 2007 | 12:11 AM
Keista's Avatar
Keista
I thought it was oil (Mobil water), but a friend said he thought it was rubber (tires) or brakes.....I smell it when I get in my garage....
Old May 7, 2007 | 01:44 AM
Bullet's Avatar
Bullet
I have it too, and what bothers me about it is that I swear it's clutch.
My 996 did not do that.
-B
Old May 7, 2007 | 05:04 AM
eljeffo64's Avatar
eljeffo64
Same here - 05 C2s and I notice the smell often (but not every trip); definitely brakes or clutch (or both) .
Old May 7, 2007 | 09:37 AM
malammik's Avatar
malammik
I think it's part of the charm driving 997. Its not sterile. It eats oil, drives fast and gets stinky. It might be by design.
Old May 7, 2007 | 10:07 AM
meaker's Avatar
meaker
I have it when, I get back from a spirited drive. I just thought it was where some rubber from rear tires got sprayed onto the exhaust...
Old May 7, 2007 | 10:24 AM
cvazquez's Avatar
cvazquez
Sounds like cosmoline, the smell will eventually dissipate around 3-5 thousand miles on the clock.
Old May 7, 2007 | 11:52 AM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
I haven't had that smell in some time now. Did for a long time. I'm approaching 11,000 miles. Will turn that this coming weekend. It's just settling in and burning things off.
Old May 7, 2007 | 01:24 PM
LA_Mike's Avatar
LA_Mike
-B
Exactly, i dont care if the car smells, but everytime i pull into the garage i think its my clutch that smells. Does cosmoline somewhat smell like a burning clutch?
My car has smelled like this evertime since I brought it home, have bout 900 miles on the clock right now.
Old May 7, 2007 | 01:36 PM
RJA in VA's Avatar
RJA in VA
Up to 73,000 miles when I sold my 993, it had a vary similar type of smell as my 997 at 400 miles does now. I assume it is characteristic of the 911 design.
