New wheels arrived yesterday
With the rear offset and rim width you are @ the same set up as a GT3 which uses 5 mm spacers. With a 9 inch front rim and 51 mm offset, you have 4 mm less clearance to the strut housing and 8 mm greater extension outwards. Have you experienced any rubbing on the fender? How much more clearance is there with the strut housing?
