Slight Wheel vibration
My car had a slight vibration as well over 50 ending around 70.Went away after 500 miles.Been perfect ever since.Riding on pirellis but will change to michelins when i have to.
Originally Posted by Paul523
DrDrilz- I had not heard of the front spring tsb which you mentioned. what year /month is your car?
Good advice from other posts above... if it's noticeable enough to bother you, I would ask the dealer do a road-force balance.
Not long after delivery I had similar problem w/my S coupe's 19" Pirelli P-Zero fronts ...front wheel vibration between 65 - 75mph, disappeared at 80+. At only 800 miles I had not hit any bad potholes yet..... the dealer was able to cure the vibration with a full road-force balance (@ $0 cost-- dealer said because of low miles; they did the re-balance in an hour while I sat in their showroom CGT pretending to drive it
They fixed the vibration by deflating and re-positioning both front tires on the wheels as the Hunter machine dictates. A lot of technical background on road-force balance> Here
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
TSB 4075 (07/05) points to creaking in the front suspension, and calls for spring replacement.
Poseur
No vibration to 180 mph with Bridgestones,--ever. No flat-spotting either,--but then, I actually drive my Porsche. (Approaching 10,000 miles). Perhaps it's the roads.
Guest
Posts: n/a
My Bridgestone's are very smooth at high speed too; it's the first drive in the a.m. or after the car has sat overnight that the steering wheel shimmies from side to side until the tires are fully warmed...never had that problem with the Pilot's even on my last 997S.
Hearing as many kudos for the Bridgestones as for the PS2s. I'm very happy with my Pirellis, but when they need replacing I might be tempted to try something different. My 993 used to have Bridgestone S02s and they were great. What B'stones are you guys wearing on the 997?
