Cold Start Issues normal?
Mar 18, 2007 | 04:40 AM
I tried starting my engine today and the engine would not start until 5 attempts.
My 07 911 has 120 miles and i could not believe this happend already.
Is this going to get better or worse? Should I have reason to be worried?
Mar 18, 2007 | 06:12 AM
Well, I'd be a bit worried.
Mar 18, 2007 | 07:18 AM
Mar 18, 2007 | 09:03 AM
Can't be normal. I have not experienced difficulty starting my '07 997S. I would take it in to the dealer.
Mar 18, 2007 | 09:50 AM
how are you starting it? ie are you pressing on the accelerator? ordinarily it fires right up, could be debris in gas line, water etc. dealer is best bet at this point
Mar 18, 2007 | 10:24 AM
Absolutely NOT within normal limits. Take the car in and have it scanned even it it seems to be running properly once started.
Mar 18, 2007 | 02:07 PM
Hmmm. Thanks guys.
I also somtimes hear a double clicking sound when i first start my engine.
Mar 18, 2007 | 06:16 PM
Mine started all winter in below freezing Chicago weather. Shouldn't be an issue.
Mar 18, 2007 | 11:49 PM
Yep, mine started at -15 F without a single glitch - every time. I can't say the same for my BMW...
You're not touching the gas pedal, are you?
Mar 19, 2007 | 09:31 AM
does the car crank and not start or does it not crank ?
do you have floor mats?
Mar 19, 2007 | 01:01 PM
It happened after i got the car detailed and washed. It cranked 5 times and engine did not engage.
It did not do this anymore though and seems now to start normally? Should i still be worried??
I also did not depress the gas pedal. Yes i have floor mats.
Mar 19, 2007 | 02:28 PM
floor mat under the clutch pedal will do that, if the signal from the clutch switch is interupted the car goes into flood protect and shuts off the injectors for about a minute
Mar 19, 2007 | 02:33 PM
Good call, Brad. Didn't know that - thanks!
Mar 19, 2007 | 06:52 PM
Wow. Thanks for the great tip on that and i appreciate your help.
Mar 19, 2007 | 10:19 PM
Hi,
Maybe the detailers got your air filter too wet.
Paul
