Fog lights don't work. Advice?
All the other lights work including the rear fogs. I checked the fuses (all good) though the owner's manual doesn't list a fuse for the front fogs, but lists 2 for the rears. I changed the front lamps using Hoen's but they're still dead. Any advice short of a trip to the dealer?...
Originally Posted by bdmason
rear fogs ? there should be only one fog light working in the rear assuming referring to the 2005 997S .(drivers side has the workabe light) I'm not sure if this has anything to do with your problem or if you made a typo, but it is somewhere to start if both rear fogs are working, there might be a short of some sort. PS. I would like to know if both are working.
I installed the the hoens appearance package and had no problem with it also the city lights(rear license plate lights). Is it on your center console display alert that those 2 lights are out?
Mine was the same you misunderstood me. I installed the appearance package (fogs the marker lights that look clear until their illuminated and the city lights )plus the rear city lights(very confusing ) I would think if there is no message there's a malfunction cause I had a burnt parking light bulb and the center display picked it up.
