Airless, open sidewall tires???
I would bet it is open to make the point and by the time it goes to production it will look like a regular tire. I think wonderful idea if they can make it weight the same
Michelin Plans to:
-Concentrate on low speed and low weight and work the Tweel up to performance spec. The vertical and lateral stiffness will be optimized surpassing the regular inflated tires.
-The Tweel will deliver pneumatic-like performance in weight-carrying capacity, ride comfort, and the ability to "envelope" road hazards (great for the bad guys).
-Increased the lateral stiffness by a factor of five, making the prototype unusually responsive in its handling.
-Tire pressure, fixing flats, highway blowouts and balancing between traction and comfort could all fade into distant memory.
Originally Posted by SYMA
Hmmm
Pocket Sand
Originally Posted by Coochas
Are you getting TIREd of it? Feeling a bit flat or run down? Don't have a blow out man! I'm sure it will come around again and again.
