Opinions wanted on champion f77 package
#31
Originally Posted by Ron Adair
Mike/A.W.E. -
I just looked on your site and noticed that your exhaust systems are for manual transmissions only. What are the options on a 997S tiptronic?
There is no difference.
#35
Originally Posted by Mike/A.W.E.
Ron-
Where did you get those headlight covers for the 997?
Is that from GMG?
Is that from GMG?
The headlights are covered, but only with the Venture brand clear bra material applied by Premier Mobile.
#36
So, to somewhat paraphrase the long thread Mike at AWE referred to...
Expect gains of mid 20s to mid 30s with headers, cats, and mufflers. X51 adds 26 so it appears you can match or exceed that for a fraction of the cost.
Weight savings is 10 lbs net (note, headers are 2 lbs heavier probably due to beefier construction and equal length pipes)
Dyno runs depend on many factors, but look at the net change and not necessarily the maximum number. You might be running "low" because of fuel, temperature, airflow, etc. but the delta should show you what the improvement is.
AWE's products are backed by warranty and he offers at 30 day "no questions asked" refund policy. So, if you put it on, dyno, and don't like the results, send it back.
#37
Ron brings up a very good point.
Too many get caught up in which dyno reads high, or which reads low. Can someone tell me why that matters most?
For us, it's all about the before and after.
However, we don't use it just for that. We also use it as a tuning tool. We can simulate many different running conditions. Perfect for dialing in new software.
#38
AMEN!
#39
I haven't made my appointment yet (planning for about 30 days from now), but the local Porsche shop has a dyno and wants to see the before and after. I know they don't have the most sophisticated system, nor do they have the largest fan system in the world, but I bet I'll have a good idea of the delta unless something really strange happens to the weather in the 2.5 hours of install time (ie: Temperature goes up 20 degrees and 20% humidity).
#41
#42
Granted, the X51 has other benefits, so how about this combination... The internals, software, and intake of the X51 with some lightweight / low restriction headers, cats, and mufflers
I think many of us could not swing the X51, so modifications like these are a way for us to make up some lost performance opportunity.
#43
Link: Air intake plenums
#44
There is an extensive article in the current issue of Excellence Magazine on Champion F77 package. The gain in static PEAK horsepower or torque was very modest(<2, if I remember correctly). However, The increases in these parameters across the entire RPM range were greater. On the track, the F77 was ~2 seconds faster than the stock.
#45
Yah, only thing to remember on the F77 package is that the ECU reflash _will_ void your Porsche warranty... other than that, the airbox looks SPECTACULAR - if not a bit pricey... :-)
I think that the best first move around here for a cheap bast_rd like me - X51 headers from Suncoast to cover the "dirty" side... I'll worry about the "clean" side (and I really love the Champion airbox) later this summer.
I'm not worried about hp or torque gains - I'm simply trying to free up my 3.8 to make it rev more easily.
-don
-don
