Tiny pink leaks
#31
ben - i believe it is the water pump... look at your picture, flip the pump over and it mounts to the engine...
the thick hose attaches to that inlet on the water pump.... thats where i saw a few leaks from my old 996.
#32
Curious minds want to know.
#33
Just follow the hose - you don't get many of the large coolant hoses on the engine, and there's absolutely going to be a feed to the pump.
Could be as simple as a poor connection to the pump - bad pump interface to engine - bad pump itself.
Either way, the dealership needs to do better than the twisted cap brush-off, as it appears to be getting worse.
#38
Originally Posted by 99firehawk
that is the water pump leaking out the weep hole, guarneteed
#39
Hey Dan, remind me not to take my car in to where you get yours serviced.
#40
Poseur
Thanks guys. I'm sort of interested in seeing how the dealership (SB Auto Group) handle it. I happen to know a lot about older Porsches and not the wet ones, so to quickly dismiss this as a crooked coolant cap doesn't pass my sanity test. I looked at the maintenance procedures (thanks , Ben) and find that their troubleshooting guidance is pretty vague, and unless done by a smart guy, may not be thorough. Fortunately, well inside the warranty.
#41
Originally Posted by OCBen
If so, what does that say for his dealership's technical staff? They probably never put it on a rack to examine it.
#42
i would definatly say by the pictures that its the water pump leaking
He only has close to 9k miles on the car. I can't see a water pump on a Porsche going out in less than 9k miles. I would hope they're good for at least 100k miles.
I still think the problem is with the gasket not sealing properly - for whatever reason - thus causing coolant to seep out gradually, dissolving the red gasket cement as it does and creating this pinkish thick goo.
Step right up and place your bets, gentlemen. My money's on the failed gasket.
#44
there is nothing on the gaskets the gsakets are stamped steel no sealant.
coolant in porsches is red/pink now, has been for 3 years
Deanski
#45
Here's a pic of my coolant fill reservoir on the left with the blue cap, and sure as **** it's frickin pink! You learn sumthin new everyday!
Well, I only had a nickle riding on the bet anyway.
