Garage Floor
Originally Posted by wilfred
QKENUFF,
I plan on doing the same thing in a month or so, couple questions since you have done it 3 times more than i have
1) Do I still need to buy the extra muratic acid if i am going to do this on a newly constructed house?
2) I thought the kit comes with final clear coat already, are you recommending an extra layer on top?
Thanks!
Thanks!
* 1 Yes. new garages often have a smooth finish with a motor- trowel finish. The acid etchies it slightly and the mechanical grip is KEY to years fo lift free paint.
* 2 The kit is a 2 part Epoxy with paint chips and does NOT include a clear coat. It must be purchased sepaaratly along with the small bags of texture (non slip sand-stuff). The clear coat should be applied after a day or two after the epoxy & chips.
Best of luck
Don't buy any of that consumer based stuff, use what the pro's use for Marine, (my business) and industrial uses.
Nothing comes close to this stuff
http://www.sherlink.com/sher-link/Im...epoxy_8-22.pdf
We are having a local company do ours next week. 3 steps - grinding floor to get a perfect surface, apply an epoxy base coat (day one) and next day apply the epoxy coating. It is a 2 day process. No muriatic acid.
I finished mine about 3 months ago... very happy with the outcome.
The following 2 users liked this post by Bwoy1981:
tegraphile (03-29-2022),
wndsnd (04-02-2022)
