How to remove brake reservoir screen
Old 01-29-2007 | 12:07 PM
elh0102's Avatar
elh0102
Default How to remove brake reservoir screen
In preparation for my first brake flush on this car, I was inspecting the screen filter, trying to decide how best to remove it. I know all the DIY comments refer to giving it a twist with needle nose pliers, which I tried. Given the way the reservoir is mounted to the master cylinder, and, that you can't get to it to support it while tugging on the screen, I was reluctant to use too much pressure. I have considered using a wire cutter and making one or two small cuts at the top of the filter, which should make it easier to remove. Any suggestions?
Old 01-29-2007 | 01:47 PM
nkhalidi's Avatar
nkhalidi
Why are you trying to remove the reservoir screen? Turkey baster method? Just hook up a pressure bleeder and go.
Old 01-29-2007 | 02:45 PM
jnx's Avatar
jnx
The screen is supposed to be removed prior to hooking up a pressure bleeder.
Old 01-29-2007 | 03:32 PM
elh0102's Avatar
elh0102
Any suggestion on technique, other than twisting and pulling with pliers? Seems that a small cut or two at top should relieve the tension of the plastic some.
Old 01-29-2007 | 06:36 PM
Paul S.'s Avatar
Paul S.
That's not necessary--the only reason to remove the screen is to siphon off the existing fluid before you start. On my 01 996 Turbo, the screen lifted out easily; on my 02 Boxster S it didn't, so I never forced things and just hooked up the Motive Power Bleeder with it in place; haven't done my 997 S yet, so I don't know, but same answer. It it doesn't easily come out, I will just hook up the bleeder with it in place (hurts nothing).
Old 01-29-2007 | 06:46 PM
jnx's Avatar
jnx
Sorry, but I humbly disagree.
Old 01-29-2007 | 09:26 PM
elh0102's Avatar
elh0102
Well, I went in the garage tonight prepared to do battle with the screen filter. And, it popped right out! I pushed the needle-nose pliers down a bit deeper, and turned the whole filter just a bit, and it came right out. It's cold tonight, so I haven't taken the time to look at it closely, but it is probably made to come out when turned to a certain point.
I flushed my M3 brakes with the screen in place; never could get the thing out. I can't see that it would do any harm, but I had rather have it out.
