Is 315/25/19 too big for rear?
Originally Posted by cdodkin
Dave,
I'm running 235/35/19 and 315/25/19 on 19"S Rims - Toyo T1R
Fit is excellent - tire wall support is not an issue on the 11" rear wheel.
235 is optimal for the front, 245 is too wide and will give you issues with turn in and cornering feedback unless you're going to start running race car camber etc on your road vehicle.
If you want to run race set-up on the road then you're left dealing with the un-even wear it will generate, and a less than happy car cornering at slower speeds.
Visually the 235 and 315 look very well balanced, and when driving the result is well balanced and a nice firm ride.
Dave
Originally Posted by Dave07997S
You know I saw the 305's on the S wheel and I thought it looked a tad pinch. Also I have T1R's on my M3 now and they run a tad narrow for their sizes. How's the ride with the 25 aspect tire?? You are down to 25.2" is it kind of jarring??
Dave
Dave
The extra width on the 315 really helps provide a protective bead to the edge of the rim, and this is going to be a key feature for keeping that lip looking new over the years.
