Waxing clear bra
Old Jan 15, 2007 | 07:47 PM
D.D.'s Avatar
D.D.
Default Waxing clear bra
Can you wax over the clear bras? I've heard conflicting reports as to weather to wax over the bra not. If you cannot, then how do you protect the paint from sun fading?
Old Jan 15, 2007 | 08:02 PM
Charlie C's Avatar
Charlie C
Porsche Nut
When I've waxed my car, I've done so right over the clear bra. Never gave it a second thought. I can't say if I was right or wrong, only that I did it and see no problem. I think wax makes it easier to get the bugs etc. off too.
Old Jan 15, 2007 | 08:09 PM
clif's Avatar
clif
you can wax it or put plexxus on it. i like the plexus as it keeps it supple and cleans it. you can then wax it as well
Old Jan 15, 2007 | 08:47 PM
vbizguy's Avatar
vbizguy
I was told by the Premier guys to wax it once a month. I use One Grand Blitz wax and it looks perfect, but I'm sure any high-quality wax will do. Plexus for scratches and blemishes, then wax. Just take care not to wax over the edge of the film, otherwise you'll end up seeing the seams. A real PITA to get the wax off the edges.
Old Jan 15, 2007 | 09:08 PM
JFScheck's Avatar
JFScheck
YES - that is if you have a high quality bra that has a clear coat on it such as a 3M product...
IN FACT - once you wax the whole car (to include the bra) it just disappears...
Old Jan 15, 2007 | 10:51 PM
mdrums's Avatar
mdrums
Use Plexus on the clear bra.
Old Jan 16, 2007 | 12:39 AM
uzj100's Avatar
uzj100
I just tried Optimum's Poly Seal. Took some minor marring out and buffed off very easily
Old Jan 16, 2007 | 01:23 AM
Pete Lech's Avatar
Pete Lech
Lifetime Member
My installer specifically said to keep the film waxed.
I'll second that comment about being careful about wax in the the edges - get some very thin masking tape and tape them off first.
Old Jan 16, 2007 | 03:38 AM
Dro's Avatar
Dro
+1
Then i add a coat of P21S.
Old Jan 16, 2007 | 07:38 AM
Deanski's Avatar
Deanski
Although you can "wax" a clear paint film, it's better to use a sealant on it as most sealants are very clear, where wax has a haze to it. In time, it can start to give the film a bit of a yellow hue to it. When I removed several clear films prior to polishing the finish for another replacement, I show the customer what it looks like. Most have a yellow hue. Some faint, some very yellow.
Wax as good as it is, you have to remember, that you are adding carnuba and oils/silicones which if you put this on glass, you'll find how much of a film haze you have. This is how waxes deepens and makes the finish look wet.
Sealants, some do the opposite and make the finish look very reflective due to the clear nature of them. Sealants like Klasse, Blackfire, Werkstatt, Zaino, Optimum, Rejex etc all are good. Klasse AIO is not only a sealant, but a cleaner as well.
Better still, as others would tell you PLEXUS is the way to maintain it. It is designed for plastics. It's also wise to find out which film you have first. From there, always research with the Mfg besides the installer. Asking the Mfg will give you the best answer.
Remember to do whichever you choose to the film, that the film is cool. Films too warm will remove fibers from MF towels and leave them on the film. The film becomes soft and sticky when very warm.
As for wax/sealants between film and finish, use great care in removing it. Not only can you possibly damage the finish, but lift the film edge as well. If you did not tape or protect the edge, soak the edge qith a QD and use a brush with natural fibers that are firm, but not too stiff and lightly brush the edge while you wipe.
These films can be a big lifesaver of paint. I had a rubber flap bounce off the hood. Damage the film, but finish is perfect!!
Regards,
Deanski
Old Jan 16, 2007 | 08:36 AM
D.D.'s Avatar
D.D.
Thanks Deanski for the write up! I appreciate your experience and will take all under advisement. I use PLEXUS on my boat and am familiar how it works in that environment. I guess my only real concern is keeping the edge free from wax. There have been suggestions to use painters tape on the edge first and then wax. I do use a quick spray wax after washing just to spruce up. I understand that I should not use wax on the film for fear of yellowing. My car is Midnight Blue.
Old Jan 16, 2007 | 12:37 PM
JFScheck's Avatar
JFScheck
Use a high quality wax, wipe it right off and you will have no problems.
I have clear bra on all four of my cars - no problems waxing between the seams...
Old Jan 16, 2007 | 07:09 PM
diverdan's Avatar
diverdan
Premier did mine and they waxed it immediately after installation: I believe they use Meguires.
Old Jan 16, 2007 | 10:10 PM
Pete Lech's Avatar
Pete Lech
Lifetime Member
Regards,
Deanski
When I had thi problem on the CC at the Parade, I tried Meguiar's and Mother's QD, and they did not remove the wax. I spotted Mr. Griot hissownself walking by and asked him - we tried his QD with a microfiber cloth and it removed the wax!
Not a commercial for Griot' s products, but I am sure glad it worked. They did sponsor the wash and prep station at the hotel, which was very much appreciated.
