Engine Knock
Poseur
Engine Knock
Is anyone else hearing the common sound of engine knocking (at least starting to) when you accelerate with the typical fuel we find in California (91 octane)? I hear it and then it goes away,--like the Vario-Valve is detuning actively to adjust. Maybe I'm not describing it well, but it sure sounds like that engine knock sound I used to hear years ago. Obviously, it doesn't last long,--maybe a second or so.
mine did it when I first bought it, but I immediately put in a tank of Unocal 91 one and no sounds since.
I just started noticing this in my '06 C2S after major engine work (replaced head gasket). The knocking appears very infrequently. In fact, for me it seems that it happens between shifts and *not* under load. I have not been able to reproduce this under load at any time.
I always use 92 octane gas from either Chevron or 76 here in WA.
Test with Ocatane Booster
As suggested by another poster, please add octane booster and let us know whether the sound goes away. If confirmed, this suggests to me that CA cars should get ECU updates to detune to 91 octane. After all, you aren't doing your engine any favors even if the knocking is very brief.
Such a shame...
Such a shame...
