An upgrade
Originally Posted by Tedder Bear
Elusive ... besides the clear markers (and winter garage project) you may want to add changing your avatar to your list. A pic of the upgrade would be nice
Fixed!
Originally Posted by DrDrilZ
nice car! totally off topic but i gotta ask.....why do they not finish the walls in garages in some parts of the country? (i assume im seeing bare sheetrock with tape and mud) i dont see garages like that here in georgia. but it seems like that is common in some areas as i see it in a lot of pics. nice floor by the way!
Memphis - cheaper house was drywalled - finished and painted.
Tampa - was bare concrete blocks (no drywall) but was painted.
Tampa2 - house 2x the first house dollars - same block finish.
Seattle - house 2x the tampa2 house $ - unfinished drywall (taped seams) like his.
Dallas - same $ as Seattle house - finished and painted drywall.
(no ryme or reason I can think of)
RB
Newbies Hospitality Director
Originally Posted by ELUSIVE
Thanks everyone for the comments. I'm really enjoying the car so far and can't wait to drive it more. Still not sure about the getting a new car on Halloween...but we'll see how it pans out.
Snickryder - You can drive the car anytime!
DrDrilz - I have no idea why they don't finish the walls, but that is definitely a winter project of mine. I'm going to have to sand it al down and then paint. Should look pretty good after a few days of manual labor.
Originally Posted by msh26
The obvious question here is the compare on the 987S to the new ride. I would thoroughly enjoy your comments on the switch.
Mike
Mike
COMFORT:
As I've stated before on this forum, I was never completely comfortable in the 987S. I'm 6'2" and about 210 pounds and I always had a hard time getting the right seating position. If my wife drove the car and moved the seat I was screwed for awhile until I could get the seat back to a semi-comfortable position. The 997S has WAY more room. In fact, when I first got in it I put the seat all the way back and couldn't even get the clutch in. The power seat option with memory was a requirement on the 997S. This will be a life saver I think. Aside from the comfort of the seating position, the interior feels so similar to the 987S. So many of the parts seem exactly the same. It was a very easy transition. The PCM will take some getting used to.
ENGINE
Powerwise, I could feel the difference in torque immediately. It definitely has more juice when you get on it. I'm trying to properly break in the motor and it only has 80 miles on it right now. I haven't really pushed the car past maybe 4500 RPM...so in this department there is still a lot to be determined. The Boxster felt to me as if it could use more power for the stability of the chasis.
From a sound perspective, the 997S engine is much quiter inside of the cabin that the 987S....but I think that its girthier outside of the cabin. I really enjoyed hearing the engine in the 987S, but I can say that I certainly haven't missed it on the 997S either.
HANDLING
Handling doesn't feel quite as precise as the 987S...but i really haven't pushed it at all yet. I'll experiment more with this one this weekend.
BRAKES
They seem very similar to the 987S
This weekend is supposed to be in the 60's and I'm looking forward to getting a ton of seat time in this beauty. The 997S has more gadgets than my 987S had as well (PASM, Sport Chrono, PCM)...so i'm looking forward to experimenting with those as well.
Originally Posted by gota911
OT: make sure you lay down a coat of primer first. With the potential for higher heat and humidity in a garage, an initial coat of primer will help ensure that the paint will "bond" well to the walls.
