997 Smart Key ADVICE!!!
1 Post
I am now hesitant to install this product......Been reading all the difficulties, and am considering returning this product. I decided to wait till others have done the install BEFORE I do mine for the above reasons..Any other feel this way?
Install is not that difficult if you are careful and follow directions, make sure all connections in plugs are solid, and treat the yellow & black wires with care!!
make sure you dissect the yellow & black wires at the bottom far enough down so they are free and can be moved up on the left so you can mount the module above as is shown. I covered the tips of 1,2,3,4 with shrink wrap so there is no shorting if they bend. Be careful of the thin yellow/black tips.
Remember how the cap goes back on the plugs after you take them apart, I had to fiddle because I forgot how they go back on.
Otherwise it's a piece of cake..
It's a great module.
Not difficult at all... Just make sure all the connections are solid. (don't mean to beat a dead horse) The little silver colored "keeper" that holds the small plug in place is pretty flemsy. When you depress it to remove the small plug from the larger one, it may not retain enough spring to lock back in place when you reinstall it. Just make sure it sticks out far enough to re-catch in the mechanism when you reinstall. I had to bend mine out a little because it was not catching properly. Unfortunately for me, I didn't notice it was loose until I got the "air bag" message (in the screen at the bottom of the tach) and had to go back and redo it. After redoing it, the message did not return, but the idiot light stays on and apparently can not be turned off without a PIWIS machine.
I finally installed my RemoteKey yesterday without any problems following the directions completely. Tested the installation by closing the driver's door and locking/unlocking the car with the remote and hearing the beeps per instrucitons. Did not drive the car until this evening. After getting in the car, I noticed the indicator and warning lights on the instrument panel and the air condition screen panel briefly blinked after (windows completetly closed) I shut the driver's door. Drove the car, parked and noticed this thing happening again after sutting the driver's door. So to experiment, I opened and closed the driver's door a few times and each time the lights/AC screen blinked.
Is this normal? Has anybody experiend this?
I hope I didn't messed up my car.
Thanks for your input.
Your issue sounds somewhat different than the one I experienced, but I doubt that you did any real damage. I worked through my problem with Stefan at IT. He is great to work with and appears to be very conciencious about making sure all of his customers are happy. Try giving him a call at 913-660-9064. I know you will be impressed with his desire to help.
I did not talk to Stefan but with Sven. He said what I experienced was normal. His explanation was the blinking/cycle activates the remotekey to do its functions. I think they should say that in the instructions. Anyway, I am now releived
Installed mine yesterday and freaked out when I tested it as I got a "system fault" and the buttons on my driver's door became inoperable and my car would not lock any more.
I was dreading the idea of going to the dealer...
However I checked my install and had swithced the yellow and black wires that went into the module in spot 1 and 3. Now it works like a charm.
Reason why I posted this is for people to know just in case they do the same mistake.
Also, download the instructions online as the paper you receive has small pics for install and does not have instructions on how to change the settings.
Overall, if you are very careful, follow step by step the instructions, you will be fine. This was my first electronic custom change on a car and I was fearful.
Features are well worth the $$.
I also installed mine yesterday (nice way to while away the time waiting for turkey)! No problems, no lights, no worries.
The stalk push-pull interface is really, really silly though. I would've like (and paid more for) a better interface to change the features. I now have default all-on, and I guess it's okay, but a chirp as opposed to a horn honk would be nice.
