Need a little help on wheel spacers?
Can't offer any solid advice on size selection, but these two threads show how 5mm and 14 mm spacer sets are attached to the hub respectively:
https://rennlist.com/forums/showthre...ghlight=spacer
Originally Posted by ngregson
Thanks to Chris C and Golfman. I think I'll try a set of 15mm or 17mm in the rear. Golfman, let me know how yours work out.
Nigel
Nigel
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
![](http://i112.photobucket.com/albums/n163/hguido1/adptr15stud.jpg)
Newbies Hospitality Director
Originally Posted by golfman
Thanks for the help on this one gota911.
I agree that the 5mm spacers are rather subtle, however, after installing H&R springs w/ Stock 19" S wheels, the 5mm spacers were the perfect finishing touch. Its harder to notice at stock ride height. Just my 2 cents.
Originally Posted by gota911
You are welcome! I'm glad I could help. The 15mm spacers on your 10" wheels (assuming 65mm offset) should push the wheels out about 9/16th of an inch and still be slightly inside the fender-well. They should look good!
Please correct me if I am wrong on this.
