Heard PSE For First Time
#31
Originally Posted by Rolf Stumberger
One way is to install an additional switch somewhere inside .
The switch interrupts the power to the electric solenoid valve which opens and closes the PSE exhaust pipe bypass valves .
If there is no power to the solenoid, they stay open .
I installed mine in the ashtray . It works great.
If you just want the PSE open all the time, just unplug the solenoid in the engine compartment( The brown connector just in front of the air intake box)
I am going to install the switch like yours. I can not figure out how to remove the Bose sub woofer on the back seat in order to access the wiring under there. Would glad if you can give me a pointer of how to do this.
Thanks for the help,
Sinclair
