Sooty left tailpipes pipes, engine test results:
As reported earlier, car w 4600 miles, shows sooty left tailpipes with no excessive smoking. Called in this date by dealer for "Drivability Concern Evaluation" Results:" No PIWIS faults found. Plugs removed and compared, nothing abnormal. Compression test (in BAR): 20, 20, 20.5, 20, 20, 20.5 All good compression. Leakdown test results: 10%,11%, 9%, 10%, 10%, 9% All normal leakdown results. No faults found with running of engine". No explanation here for the tailpipe discrepancy but I will sleep better tonight. Any comments or findings on other cars would be appreciated. Gerry
Originally Posted by 500
This still does not axplain the extra soot. I would not stop here and find the real cause.
Soot particle (nanosphere) formation is temperature dependent. Somebody mentioned the potential for a temp differential between the muffler banks/tailpipes and was roundly shot down a while ago; I think that that possibility should be revisited.
-don
Originally Posted by dstrimbu
Agreed. Is the soot caused by oil blowby (apparently not in your case with solid compression numbers), or by fuel / mixture issues? It's hard to imagine that Motronic 14.x is not managing fuel delivery to the nth degree - otherwise, you'd have a fault code set.
-don
-don
Wouldn't know how to proceed.
This should definitely be something that Porsche's tech team needs to research; I'm wondering how many reports of this issue have been recorded with PCNA...
-don
Understood, gpjli2. I'm not sure that I'd know what to do next, either. I don't have the equipment to test this theory.
-don
-don
Guest
Posts: n/a
If it was from both sides I personally would be ok with the findings so far, but its only from one bank of cylinders...somethings not right. I'd start looking for answers from a very well known and respected independent Porsche shop, not to fix the problem but to have them give their written opinion why this is happening and what are the possible causes, I would then take this written diagnosis to the Porsche dealership and meet with the factory service rep. Remember the more people that report this directly to the factory rep, the quicker we'll all get some sort of resolution and/or explanation.
Originally Posted by Drmark
Mine is due for the same on Monday - hoping for similar clean bill of health.
Will keep you posted.
Mark
Mark
