RETROFIT PCCB + NAV
Old Sep 10, 2006 | 10:03 PM
Steven_H's Avatar
Steven_H
Default RETROFIT PCCB + NAV
Is it possible to replace standard brakes with PCCB's? How about Navigation? Current car has both. Thinking of trading for one with neither. Would it be possible to switch the brakes and transfer the nav?
Old Sep 11, 2006 | 02:37 AM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
The brakes are extremely complex. It's not just the brakes that need to be switched over. The entire PSM side of things understands that that car has PCCB. Would you know which components would need to be switched within that subgroup? Would it be merely a software change? I suspect navigation would be a lot easier. It's not nearly as embedded in that car as the PCCB is.
Old Sep 11, 2006 | 02:55 AM
Moogle's Avatar
Moogle
Much easier and cheaper to find a car with what you want.
Old Sep 11, 2006 | 06:50 PM
Deanski's Avatar
Deanski
There is a TSB on this: 4701 to change to PCCB's part number: 997.044.600.63.
Total time units: 250 Converting brake system to PCCB includes: Remove and install wheels, removing and installing front and rear brake caliper, removing and installing front and rear brake disks, adjusting brake shoes and bleeding brake system. Code version in PSM control unit. WITHOUT: Test drive or testing the brakes on the roller brake tester.
Pepare to spend a whole lot of $$ as after-sales these rotors cost big money!
Regards,
Deanski
Old Sep 11, 2006 | 06:57 PM
allegretto's Avatar
allegretto
Looked into the PCCB's when I had my C4S. Bottom line, about 20K installed. A little cheaper if you can find a crashed one with a set. No idea on the Nav, but I mainly drive around my hometown so I really don't use it asn would have been happy to delete it.
Old Sep 12, 2006 | 01:50 PM
cvazquez's Avatar
cvazquez
Peter Smith wrote:
You are subscribed to the 997 from the PCA.org Technical Q&A Section
Classification: Accessories
Subject: Navigatiopn Retrofit
Model:
Year: 2005
Total Mileage:
Car Use: Street
Question:
Is a dealer able to retrofit the navigation module in a 05,997 with sport chrono?
Answer:
The dealer should install it pretty easily. The kit has the DVD reader for the nav disc. Antenna and cables plus the nav disc for the system. The kit retails for about 2600.00 and you will also need a fiber optic cable, there are 8 different cables depending on the option layout and if the car is 4 wheel drive or not. About 3 hours install time and you have nav.
Peter Smith - P CA WebSite - 9/11/2006
