Carrera S with 18inch tires
Originally Posted by H20NOO
I have a 997S that came with 19" wheels and am fitting 18" wheels due to their lighter weight, better ride quality, broader and less costly choice of tires. The only thing you may want to do is purchase some wheel spacers if the tires sit too far inboard. The 18" wheels I'm mounting are 18x8.5 and 18x11 with correct offsets so I don't think they will need spacers They are also more than 30lbs lighter than the stock set which will make a very noticable difference in driving dynamics, especially when combined with the >30lbs less weight the PCCB's offer.
Originally Posted by rotthaus
If you do not mind sharing, what brand are you using?
Obviously, performance is more important to me than aesthetics! They weigh:
Front: 18"x9" = 14lbs, 3oz
Rear: 18"x11" = 17lbs, 2oz
I'm also changing the lugs to a set that weigh 1.5lbs less per corner so the collective total should be about 9lbs less per corner. The PCCB also drop about 9lbs per corner so compared to a standard 997S, it should have nearly 20lbs per corner less rotating mass. Based on the widely accepted formula, that'll be like dropping nearly 400lbs of static weight from the car.
MC
MC
MC
MC
Originally Posted by Dr 997
I'm not an expert by far, but one thought is whether it will affect your speedometer/odometer if the tires are also the wrong size.
Jimmy
Jimmy
I'm awaiting the arrival of these wheels:
MC
MC
cheers
P.
Originally Posted by c70Pete
nice! those are by *far* the lightest I've seen.... who makes them and how much do they cost if you don't mind sharing?
cheers
P.
cheers
P.
They are now the wheel offered on the Mosler and Koeniggsegg supercars. I was one of the first U.S. customers (guinea pig?) and received wholesale pricing. Retail is $8500 a set through Alan or Dave at Wheelenhancement (www.wheelenhancement.com). Mine haven't arrived yet because they are made to order (size, style, offsets, and powdercoating) and take about 8 weeks to arrive. I hope to have them mounted by our 10/19 track event.
They've been track tested extensively by European Porsche tuning specialist PARR and here in the U.S. by Bill Koenig of Rennworx on his GT3. Even GM tested them on the Cadillac CTS-V a while back. They are the lightest wheel on the market.
MC
Magnesium, while very, very light, looks a bit chunky compared to aluminum. I don't think they are the best looking wheels but I'm very excited to experience the combination of ultra lightweight wheels & PCCB. I've always had more of a form follows function approach. On looks alone, I think the Kinesis wheels are really good looking.
The braking should be amazing with significantly less rotating inertia. As an interesting side point, taking nearly 20lbs off each corner would allow softer damping settings for better grip. I'll post pics and driving impressions in a month or so.
MC
MC
Poseur
...I'm also changing the lugs to a set that weigh 1.5lbs less per corner...
MC
MC
H20N00,
what size tires are you going to mount on your 18" wheels? I'm thinking about to downsize the stock wheels for track use. I have been using stock wheels/tire(Mich. PS2).
I plan to use 18" wheels with Mich. Sport Cup tires, but I want keep the tire width at 295 rather 265 on stock 18" wheels.
thx
thx
Agreed, that doesn't add up. If I'd thought about it at the time, I think it would have been obvious.
I'm going to talk with the retailer who made the claim on their website (it's not there now). The retailer's claim was 1.5lb reduction per wheel but when I read your post I was immediately concerned. The cost of the product to save 6 or 8 ounces is not justifiable (probably wasn't at 6lbs... but when you want the best/lightest, sometimes cost is a secondary consideration).
FWIW - The lugs are titanium and made by Poggipolini in Italy. I don't have a scale accurate enough to weigh them but there's a post office nearby...
MC
MC
