turn off service due message
Took a quick tour of the manual and didn't see how to turn off the Service Due in XX Days message. Any suggestions?
fyi - Car was serviced at 8500 miles (14 months old) and is now 6 mos later at 13500. No service should be due.
thanks
thanks
Reviving this old thread.
I'm wondering if anyone has found a DIY fix for this by now? My car - 2005 997.1 - has 49,000 miles on it, and it's annoyingly telling me my next service is coming up in 1000 miles every time I start the car. I called my dealer and I was told that I would need to provide "PROOF" that I performed the service because of liability issues (how does one prove that he's done something tomorrow?). Honestly, I love these cars but the dealer service departments???? Sheesh. And, from what I can see the recommended services for this car are at 40K and 60K. Something's not adding up. I hope I can figure out how to turn this "feature" off.
Dartmouth (03-17-2022)
the setting was dead obvious once in the module menu. this will work for 2005MY cars.
the foxwell would be the best value/dollar tool today as the durmatric pro design is easily a decade old now if not even older.
for 2006+ cars, the instrument cluster reset + fuse pull (for 30 secs) will be needed.
yvesvidal (03-15-2022)
I also use iCarsoft PorII to reset service light. It also work on many other Porsche models like the Macan and Cayenne. I will let you service the rear electric brake on the Macan and other good stuffs. Get one for around $200.
I use Autel MaxiAP AP200M cheap and effective https://www.amazon.com/Autel-AP200C-...09+Porsche+911
Ph997 - Where are you located? Maybe somebody nearby with a tool can meet up with you and do the reset.
I'm in south-east Charlotte and would gladly share my Durametric Pro.
Scott
Scott
8x57IRS (09-01-2022)
I use the same one on both my Porsche 997.2 4S Cab and 970 Panamera 4S. Great little computer for resetting oil and service light warnings.
Carreralicious (03-17-2022)
I recently got a iCarsoft CR-Max and was able to reset the Service Now message on my 2008 997.1. Took about a week for me to figure it out…had to select 2007 as my model year instead of the correct 2008.
