Viscosity: relative "thickness" of common fluids Check this out.
...common fluids: viscosity(approx) *
water at 70deg.F 1
blood 10
antifreeze 15
sae 10 motor or corn oil 50-100
sae 30 motor oil/syrup 150-200
sae 40 motor/ castor oil 250-500
sae 60 motor oil/glycerin 1000-2000
honey 2000-3000
molasses 5000-10,000
peanut butter 150,000-250,000
calking compound 5-10 million
window putty 100 million
Any wonder why at 0-40 engines might use oil ?![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
*from Corvette Enthusiast , 9/06
water at 70deg.F 1
blood 10
antifreeze 15
honey 2000-3000
and what about volatily (evaporation) of certain oils and the many other variables that can be a contributor to oil usage in an engine?? viscosity is rarely a reason for oil usage in engines. That chart (if it is even accurate) tells nothing relevant to oil consumption issues.
Another thing most people don't understand is that the oil temperature is measured at one of it's coolest points in it's circulation. Not many can comprehend how hot the oil is in the hottest part of the engine. The oil's ability to clean, lubricate and seal is not dependant on the temperature displayed on you gauge, but at the maximum temperature the oil reaches during it's cycle. It doesn't matter how cool it gets during the rest of it's flow.....the damage is done.
The "zero" in 0-40 would only apply at start up under certain conditions. At that point this chart suggests the oil is thinner than water. I find the whole thing interesting and intended no global implications. I will repeat, however, that my car is using much less oil at 5-40 than it did at 0-40.
