Is there a way to Remove Dust Without Washing/Detailing?
Originally Posted by mdonline
MMD,
I think it is a matter of our personality and the joy of driving around in that "concours level" car EVERY time it leaves the garage.
I also have respect, in another sense, for car owners with such high standards since I bought a concours-level TR6 many years ago and just drove the thing and did a few wax jobs now and then. Great car and I basically bought it brand new! When I sold it, it wasn't concours anymore.
Originally Posted by meaker
Have you used this product for a long time? I find it hard to believe that it won't scratch the paint. a quote from the site " Knock out the pad frequently against the palm of your other hand while using and before refolding. This helps to release the loose, heavier dirt from the napped fibers, leaving only very tiny particles that act as a polishing agent, similar to the effect of a fine jeweler's rouge. Thus the cleaning and polishing performance in one cloth." That could not be good for your paint.
Deanski
KozaK
This "hand-rubbing" effect is a continuation of the last polishing procedure done at the factory before your car goes to the dealer's show-room.
One day I should get the "test" panel (hood) that I use for testing products on and for training people how to use a rotary and hit it with a Kozak a few times and post some pics!
For those of you who feel a bit nervous using a "PC" polisher on your Porsche, go to a junk yard, find a hood that you can use. Best are dark or black hoods in somewhat good shape. Take it home, put it on some saw horses, clamp it down and go at it with your polisher and polishes/pads so you can see what each does and how much you correct. It's always better to spend a few $$ testing everything if you're not familure with polishing with a Porter-Cable. Later, you can try a rotary on the same hood. Rotary polishers works faster and better than any random orbital, but boy, you can burn paint in a heartbeat if you are not carefull!! More caution should be used around corners, bends etc(door jam area, hood openings, headlight surrounds) as they do not get as much paint coverage as say a flat panel or surface.
Have a nice day!
Regards,
Deanski
I just tried the Kozak and it seems to work quite well. Don't knock a product until you've tried it! I don't care who you are. Advertising is just that. I'm sure they are trying to sell their product any way they can. It doesn't cost too much...give it a try.
The best thing is obviously washing again. Barring that the dusters work. If you really want to brighten it up, duster, then use Meguiar's Quick Detailer with MF.(the QD acts as a lubricant to minimize scratching) Keep in mind that everything scratches to a degree. The blower idea will only get a %.(probably no differerent then just driving the car). Good luck with it.
Originally Posted by wross996tt
I just tried the Kozak and it seems to work quite well. Don't knock a product until you've tried it! ... It doesn't cost too much...give it a try.
The key pitch to any of these "miracle" products is the promise of eliminating work. How many of these do you suppose they'd sell if it actually took twice as long to use than to just wash the car? Even if it saved water or actually polished the paint in the process?
The truth is that dirt that collects on your car is random in size and texture, and thus random in abrasion. There is no way of knowing the nature of the contaminants and so there is no way of being able to put them to productive use. As I point out in my up-close look at dirt and the damage it can do to your paint in my first linked thread below, dirt is the enemy and you need to respect the amount of damage it can inflict on your p-car's soft paint finish.
Most of you know that I use magnification to examine my paint finish as I polish away the fine micro scratches that inevitably accumulate over time. (Lately it's due more to presbyopia than to my obsession with perfection. ) And you also probably know that I enjoy detailing more than driving. I'd rather spend 8 hrs detailing than 8 hrs driving -- there's no fun in driving if you can't go fast! . . . And as I've said before, the pleasure from driving on a track is over the minute the ride is. But the pleasure from detailing continues to last and last each time I glance at my beauty.
Here's a suggestion for you. It's what I do in-between washing/details. Only use this method when the car is dry, or the dust on the car is light (and not caked on). I use a swiffer hand mop. The small one with a small handle. You can also use the anti-static cloth that people use to clean polished wood surfaces (to remove light dust). They work very well, because they pick up the dirt and don't release it (because of the anti-static properties), unless you shake it very hard. And you don't end up pushing the dust from one side to another. Hope it helps. The cloth also works great for the interior, especially on small nooks/crannies, and gaps between the buttons.
Ben you are trully sick
Yep, I bought my 911 mainly to indulge my love of detailing perfection. I have never regarded it as a means of transportation -- for getting from Point A to Point B. That's what my commuter car is for. Like I said before, my biggest fantasy dream is to come up with an invisible shield for the car that would keep out all dust and contaminants, so that the car can be driven and kept in a perpetual state of perfection -- now that's what I fantasize about! . . . Sick I know.
My friend, you are one sick puppy!!!
Using de-ionized water will allow you to wash the car, removing the light dust/dirt and not have to dry the car at all (DI water will leave no water spots).
Upon coming home, you could simply lightly pressure wash the car with DI water and let it dry, no contact/scrubbing/scratches.
They advertise in Pano a 5% discount to PCA members.
www.crspotless.com
www.crspotless.com
I enjoy detailing more than driving. I'd rather spend 8 hrs detailing than 8 hrs driving.
The wife gets a bit annoyed by it, but she tolerates it, knowing that's who I am.
