A/C Issues
Well, it hit 92 degrees in Sunny Florida and my wife decided to take the Porsche to work while I was out on a business trip.
So, she just had to call me on the cell and started to complaint about my pride and joy... and the conversation when like this... the A/C unit is making funning sounds like Darth Vader
and the A/C is not cooling at the lowest setting and at maximum fan speed. And I don't want you to blame me when you get back home.
I told her to take the P-car straight to the dealership and get the system check, so she did and this is what they found.
The Freon level was low and the mechanic tested the system with leak detection dye and found nothing wrong with the system. They told me that sometimes the P-cars are shipped with low Freon levels. So if you’re getting funny vacuum noises and low cooling you might have low Freon levels.
and the A/C is not cooling at the lowest setting and at maximum fan speed. And I don't want you to blame me when you get back home.I told her to take the P-car straight to the dealership and get the system check, so she did and this is what they found.
AC on watercooled 911 are really cold. colder than most cars IMO.
Good thing the Freon is R134 and car is under warranty. Most likely, not enough freon was put in. If freon is low, don't run the AC as running the compressor with low freon will wear out the compressor faster. Freon is a lubricant.
Well, my air conditioner is back making Darth Vader noises and stop blowing cold air. The first time this happened the Porsche tech checked the system for leaks. However, the system showed no leaks, but it was very low on Freon.
This is the second ac issue, so it must be a very slow leak undetectable during the first leak test. Hopefully, the tracer color is still present in the system and it will be detectable the second time around. (fingers cross)
I have an appointment this Monday and will report back!
I just had mine worked on last week. The AC line to the condensor was loose and could not be re-attached. Also, the R134 was low. The dealer replaced the line and re-charged the R134. So far everything is working fine.
Thanks... I'll mention the above issue to them.
I had same low cooling problem with my 997 A/C in second summer of ownership. Dealer put in more Freon, and it is cooling reasonably well now, but certainly not freezing.
I do have a musty smell that they can't seem to find cause of.
Place various fans outside the doors on chairs and air-out the P-car. It seems you probably have moisture inside the car (take out the carpets and get them sun dry).
Once everything is dry, try and keep it dry...
Bottom line: Air out the P-car from the moisture/musty smell. Never clean your carpets inside the car. Clean the carpets outside the car and let them dry completely.
I hope this helps.
Sooooo...? Where's the report, hu?
I'm asking because today* I had the same experience as your wife (with regard to the car anyway). It was one of these rare days on which I had my top up because I was driving on the Interstate. I was on my way to Dallas when the a/c made Darth Vader noises and gave up cooling. Started sweating (95 degrees!), felt miserable, put top down, turned around and went to my dealer.
Apparently, I had no coolant left, but they could not find the leak either. So they filled up coolant and added dye. Now I'm supposed to see how things go. Great, quick service, though, no complaints. I was in and out in 45 minutes.
* 9000+ miles
I'm asking because today* I had the same experience as your wife (with regard to the car anyway). It was one of these rare days on which I had my top up because I was driving on the Interstate. I was on my way to Dallas when the a/c made Darth Vader noises and gave up cooling. Started sweating (95 degrees!), felt miserable, put top down, turned around and went to my dealer.Apparently, I had no coolant left, but they could not find the leak either. So they filled up coolant and added dye. Now I'm supposed to see how things go. Great, quick service, though, no complaints. I was in and out in 45 minutes.
* 9000+ miles
