Valentine 1 placement
I have gone thru the old threads, but I had a new thought.
Has anyone mounted the V1 on the BACK window passenger side, and then use the remote display unit on/in the dash. Hard-wired of course.
I get this idea from a Boxster i used to own. I mounted the V1 in that car between the seats on the rear "shelf," then hid all the wires and stuck the remote display on the left corner of the dashboard butted up against the windshield, conveniently hidden from outside view by the inspection sticker and registration sticker.
So on my new C2S, I thought of trying the same principal. One negative would be to impact the headroom for the rear seat....like that matters! hah! The rearview mirror view is not obstructed, though.
I believe with the remote display the main unit is visually muted, but i also remember needing to use black electrical tape to hide the red lights from being visible from behind. The audio over my right shoulder is no problem.
In the Boxster, the setup was pretty stealthy.
Anyone try this in 997???
I have my V1 mounted on the passenger visor and direct wired to a power source. Works fine, easy install
Poseur
The main V1 unit when used with the remote display will not light up except during its startup BIT checks. I still maintain that the best or optimal frontal detection capability will be with the antenna mounted as high as possible on the windshield.
Dan
Dan
thanks for the comments. believe it or not, i actually forgot i have the visor clip!! i never liked it visor mounted on any car before, but trying it on the 997....actually quite decent. Not great for passenger tho...or for sun glare problems.
Bob - which power source? the self dimming mirror? (read that thread...scary!!! dont think i can handle that) or did you tuck the wire around the headliner to the dash console or fuse box. I also thought the visors wilth lighted vanity mirrors would have an accessible hot wire, but havent been able to find it.
What Tom said, around the headliner and direct to the fuse box. I had a 996 Cab with the same install and it worked great. The only issue is the passanger doesn't have the use of the visor. They get over it, I have this set up in my other car too.
here is a few pics, it's dark but you get the idea
The Penguin King
posted these before.
this is how i mounted my V1. It's above the back seat with the remote in the cubby hole. works great and it's completely out of the way. i made a 'z' bracket out of home depot aluminum and tucked it under the bose subwoofer. the cable was run under the seat and through the console to the cubby hole.
![](http://webpages.charter.net/rbianconi/Porsche/%20Carrera%20997/V1back.jpg)
remote
remote
![](http://webpages.charter.net/rbianconi/Porsche/%20Carrera%20997/V1%20remote.jpg)
forgot...
The V-1 can be programed to go dark so you don't have to worry about lights flashing to the rear.
Also, i've been on lots of PCA trips though the country side with other V-1 users and mine always goes off when theirs alarm, so mounting it where i have it has had no effect on sensitivity that i can tell.
pm if you want more detail (I, like you do this inmy wife's boxster)
bob
bob
Yeah, I have the remote piece too. Even running with the lights off and top down it looks like a brick on the visor. I'll check the rear mounting method and determine it's visability. It's not hard mounted is it?
