Rubber Nose Spoiler Keeps Coming OFF
Anyone else having this problem?
I do scrape just a little bit coming and going from my own driveway (of course!), but I'm very careful, always taking the diagonal track...however, the spoiler keeps getting popped out of its holes.
It's easy enough to tab it back in place, but I'm worried I'm gonna lose the damn thing. Is there a remedy I'm overlooking?
Why didn't I think of that?
you must have a nice little bump at the head of your driveway?
i have a very steep drive but havent had any trouble popping the apron on the 997.
scraps a little if i dont angle it right but i dont pop any of the retainers out.
i did have that problem with the gt3 i had prior to this car.
if the retainers are the same on the 997 they should be relatively inexpensive and are easily replaced.
but i would do something about the head of the driveway.
probably wouldnt be that expensive to alter it enough for the 997 to clear.
mine came loose on a road trip.3 of the "clips" came off and made a loud flapping noise so i took the the whole piece off (about ten clips in total).that made the sound and vibration worse.you feel it right thru the firewall area. i brought the car in and had them put a bead of sealant or glue on the "wind deflector ".still i get a wind and vibration noise at higher speeds (above 80/85). i had a motorcycle following me and was afraid the part was giong to fall off and wipe him out. I have my dealer trying to figure it out but still no luck . it seems like there is something else that may be flapping around under there. not a good feeling . crg
