Door ding repair in OC
Can anyone recommend a good paintless door ding repair guy in So Cal. I am in the South OC area and some ahole got me dead center of the rear quarter panel right at the center of the wheel arch on the outer edge. Couldn’t be in a more noticeable spot. Looks like the guy just threw his door into it. The parking lot was dark and I did not see it until the next morning.
I am in North County and don't know what area this guy serves, but he is very good and has fixed numerous cars in our household over the years. His name is Mark Davis and he calls himself M.D. Dings. His cell number is 714-264-9607.
The worst occassion I had to call him was a few years ago for my wife's one week old Mercedes that had a ding right on the crease on the door. Mark made it go away. I have probably used him a dozen times over the years. I am a sicko when it comes to the condition of my cars, but Mark makes me well.
Phil
Phil
Lifetime Member
Lifetime Member
Blind panels are tough. I recently has South County Auto Body in Lake Forest do a rocker panel repair for me. They did a good job. They also do paintless dent removal.
Thanks Peter that will be plan B. I also had a scratch that the deal gave me on the driver’s side rocker panel. They had Sterling Collision repair and did a good job. Of course the first attempt is going to be the paint less route. But if that fails it is off to the body shop. It sure is a good thing I didn't see this happen. I would be in jail for murder right now.
Sorry to hear about your misfortune.
From your description and the location of the ding it doesn't sound like that will be repairable via the paintless dent repair process, which relies on the capability of the thin sheet metal to spring back using a special tool to get the dent to pop out. Sounds like it's suffered permanent deformation and will require a good body shop to make it like new again. You may want to get Autobahn Autobody in Costa Mesa to give you quote. They specialize in exotics and do excellent work. They worked on my car last year.
Good luck.
Good luck.
hey bigwave,
i recently had a dent fixed right above the gas cap.
my only advice is to ask a few different guys.
One body shop said it couldnt be fixed without paint, another pdr guy said it wouldnt be perfect, the guy I finally went with charged alittle more but he came out to me and did a perfect job, he does all of symbolic motors and other high end dealer cars.
he charged me $125. my dent was more of a crease than a ding, and not that easy to repair, but came out perfect.
sure fast40th,
David Pelikan
sosdent.com
310 923 5932
Extremely nice and professional guy
I thought they just massage the dent from behind the panel, (that is what I've seen before) but this guy also hammered away on my painted surface with some wierd tools I couldnt bear to watch but it really worked well.
I think the mobile thing is great if you dont have time to wait for an hour or more at a shop...
the 125 was kind of high compared to others, but he offered to fix another less noticeable ding for another $75.
I think you can get a good deal from these mobile guys if you get a few cars together.
David Pelikan
sosdent.com
310 923 5932
raffi mine is also a crease and the guy phil referred said if it does not come out perfect then no charge. He also wanted 125.00 which to me is well worth it if he can fix it. Thanks again for everyone help. I'll post the results on Tuesday after the first attempt
That is cool, considering if his method doesnt work then you can get another guy to try it.
However, I have also heard of pdr's gone wrong which ended in paint chipping requiring a repaint. I hope everything goes well, usually guys in this business as well as window chip repair always underestimate their end result so you will be happy when it comes out better than expected.
No luck with the mobil dent repair. Said it was to tough of a spot to reach. He tried for a while made it look alittle better but no go. Now i need to take it into a body shop. which means repaint
that just kills me.
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
