Retractable Spoiler
Old Mar 7, 2006 | 01:11 PM
rmklaw's Avatar
rmklaw
Default Retractable Spoiler
Is there an easy way to check if the spoiler is extending above 75 mph (short of having someone follow you)? I know it works manually, but I never know if it has extended at speed.
Old Mar 7, 2006 | 01:13 PM
stevenshin's Avatar
stevenshin
7th Gear
Sometimes you can see your reflection on a darker car/van/suv.
Old Mar 7, 2006 | 01:23 PM
Leader's Avatar
Leader
Have faith, Grasshopper.
Old Mar 7, 2006 | 04:40 PM
tnunnery's Avatar
tnunnery
It would be nice to have the indicator on the button light up when it is extended. Until there's a hack/fix, I'll just have to keep watching for those reflections too.
Old Mar 7, 2006 | 04:48 PM
cmoss
Guest
Posts: n/a
btw How do you know the light in your refrigerator goes out when you close the door?
Old Mar 7, 2006 | 04:53 PM
TT Surgeon's Avatar
TT Surgeon
If it doesn't raise, a light comes on, 'spoiler failure'.
Old Mar 7, 2006 | 04:56 PM
gota911's Avatar
gota911
Newbies Hospitality Director
I was not aware that you guys could not see the tail in the "up" position. I can see it on my 996. I understand that the 997 seats sit lower than the 996 seats. Is the lower edge of the rear window higher on a 997 than on the 996? Or maybe the wing does not raise as high on the 997? It would be interesting to know the reason(s) why it can't be seen in the 997. Any other thoughts?
Old Mar 7, 2006 | 05:00 PM
bellatrix's Avatar
bellatrix
When I'm driving mine over 130 kph, it's usually because I'm on my way to 230 kph, so I'm watching in front, not behind!
Old Mar 7, 2006 | 05:03 PM
rmklaw's Avatar
rmklaw
I did not realize that there was a spoiler failure light if it does not raise. Looking for reflections on cars to the side at 75 mph could result in more than just a spoiler failure.
Old Mar 7, 2006 | 05:59 PM
stevenshin's Avatar
stevenshin
7th Gear
I believe the 997 wing does not raise as high as the 996. When it is up, it is almost flat (parallel to the ground).
Old Mar 7, 2006 | 06:57 PM
Ronnie's Avatar
Ronnie
stick a wireless webcam in there... note light on when the door is open and light off when the door is shut.
good god i need to get a life !!!
Old Mar 7, 2006 | 07:34 PM
Legalkix's Avatar
Legalkix
pipe the webcam to the PCM and go out and buy a MOST harness to hook it in so you can monitor it while driving. Extra switch on the PCM is gonna be what breaks you though...
Old Mar 7, 2006 | 08:34 PM
fluid15's Avatar
fluid15
With my past 993, I could often watch it raise by it's shadow, when I was driving north/south late in the afternoon (or morning). But typically, whenever I wanted to see this someone would pull up next to me and block my view!
Old Mar 7, 2006 | 09:11 PM
THPorsche's Avatar
THPorsche
that's the reason why Porsche gives you a sunroof, you can stick your cell phone out and take a pic.
Old Mar 7, 2006 | 09:28 PM
1080iAddict's Avatar
1080iAddict
Better yet, buy this webcam:
http://www.smarthome.com/971354.html
Then hook it up into a wireless modem and post the IP address so we can all stare at our computers in between posts to see if your spoiler is raised.
