Exhaust Tips Question
Old Mar 2, 2006 | 01:59 PM
JC 911's Avatar
JC 911
Default Exhaust Tips Question
Does anyone know if the dual exhaust tips that are standrad on the 997S will fit on a 997 non-S?
Old Mar 2, 2006 | 02:33 PM
THPorsche's Avatar
THPorsche
well, I asked this exact question 4 months ago and am still waiting for the answer.
Old Mar 2, 2006 | 02:52 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
You know if you follow around behind an S car that hasn't been in yet for the recall you may discover an inexpensive source for them!
dan
Old Mar 2, 2006 | 04:51 PM
ronmart's Avatar
ronmart
dan
Excellent!
Old Mar 3, 2006 | 01:32 AM
jcnesq's Avatar
jcnesq
Miserable Old Bastard
The standard mufflers are the same on C2 and C2S, so at least in theory the S tips should fit, unless there is some difference in the cutout on the rear bumper (which I highly doubt). And yes, the 05 and early 06 S tips have been recalled.
Old Mar 8, 2006 | 10:36 PM
md11plt's Avatar
md11plt
I do not believe that they will fit. All the tip manufacturers specify S or Carrera. There is a solution I believe: http://www.cargraphic.de/index.php?/s,6,7,18,1771,1947/ They have an adapter at the bottom of the page. You can also try here: http://www.cargraphic.de/stepone/dat...0/997_1105.pdf
Old Mar 11, 2006 | 10:19 AM
Phin1's Avatar
Phin1
3rd Gear
The Carrara S exhaust tips don't fit the Carrera (non S)...because the diameter for the S is larger. But the adapter kits should definitely work. If you remove your exhaust tip, there is a metal bushing inside. Instead of the adapter kit, you can overlap the S bushing on top of the Carrera bushing and the tips will fit.
Old Mar 11, 2006 | 12:11 PM
MMD's Avatar
MMD
I'd like to go the other way; put non-s tips on my s. The fake quads bother me because they're fake AND the oval tips look better (less cluttered rear view).
Old Mar 11, 2006 | 09:02 PM
rotthaus's Avatar
rotthaus
I have been thinking about doing the same thing. When I get her out of storage next month and take her in for the recall I was planning on asking for the regular Carrera tips instead. We will see if my dealer will care what flavor tips they install.
Old Mar 12, 2006 | 03:45 PM
SrfCity's Avatar
SrfCity
Anyone else not rushing to do this recall? I plan to do it at some point but not really feeling any urgency. Maybe if I blow the tips off one day I'll get right on it
Old Mar 15, 2006 | 03:20 PM
JC 911's Avatar
JC 911
Default Adapter Kit??
Just saw the post about an adapter kit for the exhaust tips on a 911. Is this adapter kit from Porsche or that cargraphics place?
Old Mar 15, 2006 | 03:38 PM
cvazquez's Avatar
cvazquez
Sorry, they do not fit.
Old Mar 19, 2006 | 04:28 PM
JC 911's Avatar
JC 911
Default Solved!!!!
Okay - I have it solved now!
The exhaust pipe for the S is about a 1/2" bigger than the non-S. So you need to get something to make up that difference. Assuming you already have the dual exhaust tips in hand, what you need to do is go to your local Pepe Boys/AutoZone type store and buy a 2 1/4" bushing (which costs like $3.00 a piece). Take off the exhaust tip on your non-S and then take out the bushing thats in it already. Place the 2 1/4" bushing you bought from your local auto store into the circular opening in the back for the dual exhaust tip. Then place the bushing from your old exhaust tip into the 2 1/4" bushing. Then place the dual exhaust tip into the tailpipe and tighten the lug nut. It took me a few times to get the new dual exhaust tip centered properly but I finally got it in the spot where I wanted it.
Old Mar 19, 2006 | 09:19 PM
THPorsche's Avatar
THPorsche
How much did you pay for the S tips (chrome?)? How about some pics if you don't mind? Thanks.
