Hard wire to fuse box
I am not sure if the fuse assignments on that row. However, you will get PASM fault when disconnecting the battery for example. Usually, these faults clear when you start up the car and drive a little distance. Drive round the block and turn off and on again. See if that does the trick. It is unlikely you have done anything to damage anything.
m1kegibson (05-13-2020)
